Scythe Kama-Bay
8 Jun 2003
NBO
As above, anyone got one of those? Just curious if its a dust-mite & if you'd recommend it? Also, is it possible to change the fan?
Want to give my aging, case a 'boost' :o
a lot of people think they a pretty decent. Though I dont have one myself. :(
Yes you can change the fan but i dont think there would be any need. Unless you want an LED fan or something.
Yes, you can change the fan (just screwed in). The only issue I've had is with an annoying clicking noise, which I think is the fan catching on the dust protector stuff at the front (removable though, and I'm sure a re-seat of the fan would fix the prob for me..lazy).
I've got a silver version. They're good and don't pull too much dust in at all. Using a sharkoon 1000 in mine!
Putting it up for sale in the MM soon as i've ordered an official Lian Li version so keep an eye out. :)
gt
