- 16 Mar 2011
- Leeds
Scythe Kaze Master Pro - Fan Controller - Screen Problem
Hi
I have just purchased a 5.25" Scythe Kaze Master Pro 6 Channel Fan Controller, The install went well if a little messy as I know I am replacing all my case fans very soon so I didn't go all out to tidy it all up but it all worked first boot after install.
I seem to have a problem with the screen not coming on if the machine has been switched off for an hour or so. The screen definatly has power as I can see the horizontal red lines come on which is part of the matrix.
If I turn off the power and reboot a coulple of times the screen seems to start to come to life, dim at first then suddely fine. If I turn off and back on again after a few minutes its all fine, but leave it again for an hour and it doesn't work again.
Do you think this is a faulty item or am I missing something, this is the first fan controller I have ever used thats all.
Any help would be appreciated.
Hi
