Scythe - Mugen 5 PCGH Edition 43.03 CFM CPU Cooler
4 Apr 2019
Hi just a simple question really, Does anybody know if this
Will fit in the
Lian-Li PC-O11 Air Midi Tower
I think it might be a tight fit but I'm unsure
Thanks in advance.
Top down cooler, that is the only one that can match flagship tower coolers with 220w of TDP
My basket at Overclockers UK:
Total: £85.69 (includes shipping: £8.70)
At 130mm will fit in with clearance of air . Also design of Dynamic means air will be recycled less with a Top down Cooler design
Had the ability to fit over the tallest of ram too
Thanks for the replies. Water cooling is probably the better option but arbitrarily it makes me nervous. I think I'll go with the cooler above (Dark Rock TFU cooler). I just need to save the pennies now for a month so i can afford it all.
Anyway thanks again you have been very helpful.
