A quick question mid build....
Building my new Conroe Rig - E6600 on a Gig. DS4 MB.
Done plenty of home builds before. Parts mirror recommendations on forums.
I think I have a problem with the Ninja's fan starting?
The PC's starting up fine but using the motherboard cpu fan power, the Ninja's fan almost starts up (small movement) but then doesn't. Will start fully if you give it a spin. The Fan seems fine?
The fan works fine if I use alternative power source.
Question - Do I have a problem? OR is it the motherboard clever and only starts up the fan if the CPU heat builds? I'd hate to fiddle for much longer to find out it's a 'feature' !
Cheers
Cheers
