Is it worth buying the H50 when the 1156 bracket is available or will the Scythe Ninja II Rev B do the Job of An i5 750 @ 4ghz OC stable? I saw a post with someone using the Scythe Ninja II and It hit around 70-72 degrees which im guessing is Good? Is it worth Spending Almost Double the Amount for the H50 or is it worth getting the Scythe Ninja At a little over half of what the H50 costs.
Also Does the Fan for cooling the H50 Need to be blowing into the case? If it does, will it mess up Airflow much or not?
Thanks.
Thanks.
