Well folks I just lapped my Scythe Ninja HSF that sits on my Q6600 G0. I have attached some pics, but unfortunately I didn't have any industrial polish to polish the cooler at the end. I guess after the AS5 has settled in (200hrs) I will be able to tell what temp drops are like.
I used dry/wet sandpaper with the following grit: 180, 360, 800, 1200
Here is the gear I used, I made sure the water was warm and soapy as the sandpaper does a much better job with that mixture. I didn't need to use the metholated spirits as the acetone did the job at cleaning out the AS5 thermal paste from the base of the HSF.
The Scythe Ninja HSF had to have the mounting clips removed and to od that the base was unscrewed.
I started of with grit 280 and made sure the Scythe Ninja HSF was firmly fixed to the sandpaper and as flat as possible, the HSF was then moved in circular motions until I could feel it easier to move around - I then moved to the next grit that being 360. I found that by 800 I was pretty much able to iron out any scratches or markings - I did move to 1200 grit - the whole process took about 30mins.
I have a feeling my CPU may not be flat though as I still get a 8 degree temp difference between Core 1 and 3, and I really wish I had some boot polish to show the results properly!
