Scythe ninja or coolermaster hyper tx ?
3 Apr 2007
Land of the sheep
Im stuck on choice :rolleyes:
I want a heatsink which has great cooling for Ocing but also easy to install and remove.
I have heard good things about scythe, but heard they are a pain to remove and also that the push pins are too weak to support this monster,so any experiences would be helpful ;)
I suppose i would try other recommended alternatives :)
Christian
True that the scythe can be a bit fiddly, but as far as i have seen with mine, they support it fine.
Only problem i had was with a known issue with the DS3 and the capacitors round the socket getting in the way. A quick mod and this was sorted, temps i am very pleased with too.
