- 12 Jan 2006
I have bought 2 aksa Ultra Quiet 12 cm fan's to replace the one thats provided with the cooler,
what i want to achieve is:
Would it be viable to simpy get a fan grill to put over the fan blades of fan 2 and use some metal wire to create some holders similar to those provided with the fan? or will that cause problems?
My alternative plan was to have 3 fans, 2 blowing air into the heatsink and 1 pulling the hot air out
Or am i just going overkill and i wont notice any difference in temps
Thanks in advance
Thanks in advance
i was bored, even tried getting a Zalman Flower Cooler onto a Socket A this morning. Managed to fit it on with a bit of playing, but couldnt find the 2 to 4pin converter, doh!
