Is the Scythe Ninja Plus the best option if you intend to use the 120mm fan?
i.e. is the whole point of the cooler that it can be used passive?
My a64 3200+ @2.5ghz, 1.45v is idling at up to 38/39c and I would like to drop it a bit if possible!
Also can someone recommend a 120mm case fan to add to my Sonata II or would a second Antec one be just as good?
Thanks
Thanks
