Anyone using the:
Scythe NINJA PLUS Rev.B" 6Heat Pipes CPU Cooler
or
Thermalright HR-01
With no fan? If so, what are your specs? Any good? What CPU (Max) can the Fanless version be used for?
I want to use one without a fan. I have an AMD 3500 CPU.
Out of the 2 above, which would you recommend as the best for cooling and no noise?
or
Thermalright HR-01
