Hi again, well it's big, much bigger than I thought it would be. I ended up taking out my motherboard tray and removing my graphics card before I fitted it as I thought it would make it easier. However after putting it all together, I did do some trial runs fastening the heatsink first before I used any goop, I found I couldn't insert the tray as the fan hit the case.
Still, after about an hour, it all went in ok, didn't have to remove my memory modules though, unlike you did Marakith, you were right about the fan fasteners look different to what's in the picture.
I'm fairly happy with my temps now though, with a overclock at 2.8ghz Probe is saying CPU @ 25c idle and motherboard @ 42C. However Intel TAT says CPU @ 41 rising to 62C under loard. From the looking at probe it looks like the fan is not being increased in speed to compensate for any addtional heat -
I think I'll have to investigate why that is but any contributions would be of help....
Thanks,
ChrisC
