- 27 Oct 2006
- London
Anyone know if I can get a ninja onto an old Socket A athlon motherboard ?
Cheers
Cheers
BillytheImpaler said:I suspect not as it doesn't list compatibility. However, if you wanted to fabricate your own mounting mechanism you could make it happen.
Jonny L said:Don't think you can, but you can fit a titan vanessa if that is any help to you.
Well how much effort do you want to put into it? Anything's possible if you invest enough effort.Subliminal Aura said:Yeh this is what I'm hoping for - Those Socket A jet engines a f'ing noisy
BillytheImpaler said:Well how much effort do you want to put into it? Anything's possible if you invest enough effort.
The Scythe Katana Cu would fit without modification.
