My question is should the fan be set to suck air from outside the case over the heatsink and RAM OR should it be set to suck air from inside the case from above the RAM over the heatsink and out the back.
Which is better for CPU and overall system temps. There are of course other considerations such as the PSU, read on for full details on the system.
I've got a Scythe Ninja Plus Rev. B with a 120mm fan that sucks air over the truly massive heatsink. I have a medium tower case with the Hiper HPU-4M580 PSU sucking in air for itself above it (most of it going out the back, but there are holes in the PSU case so some probably circulates back into the case).
Below the scythe, but with good separation, is the motherboard's (MSI P965 Platinum Intel P965) heatsink and below that the Gfx as usual.
On the right side are the driver bays. The SATAII HDs (2) are well below the heatsink and so well out of the way, the DVD drives are well above, so its really plenty of space on this side, although it's also of course where the RAM is. On the left side are big ventilator holes in the case.
Very crude diagram to illustrate airflow. Arrows show airflow, it's not as much space between PSU and Scythe as shown. More like a few centimeters or 1-2 inches. (ignore the dots)
back ______________front
..<-..|PSU]...............|
<->?|.[Scythe] [RAM]|
.......|.....[HEATSINK].|
.......|.[GFX].............|
.......|.[PCI, etc.]......|
