. To be honest with you, it's quite tricky to install, and I found myself using a LOT of power to push it on. Once you've got it on it sits perfectly. The first time I was afraid I damaged something, but fortunately I didn't.
. I can't wait to see a comparison between the big typhoon and this one
. But I love the fact that the air is getting blown backwards in my case, straight to my 120mm exhaust fan.
HighlandeR said:Just a word of warning....
That backplate that comes with the ninja is VERY VERY EVIL, its metalic and I found after the installation all was ok but randomly my PC would restart/shutdown or sometimes wouldnt even switch on.
Went thru 100+ hour diagnostic mode/testing memory/p/s and hdd and cpu in end was about to give up but then thought what have I changed recently and yeap the ninja !
Ended up fitting on the old AMD stock heatsink and didnt get the issues so fitted the old AMD PLASTIC mobo backplate heatsink and then modded it with longer screws so the ninja fitted on perfectly.
Turned out it was somehow shorting out my mobo...
Sorta a nightmare lol but got there in the end and the 120mm silent fan thats on it is awesome.
Yeah the clips a bit hard to get on the more u put it on and off the looser it gets though...
Well no problems for me, the isolating works fine, and seems a lot more robust than those made of plastic(would be surprised if it wasn't, as it's made of solid metal
Actually fitting the retention bracket obviously is easy, but it takes a bit of power to clip the Ninja into it, trying ot make sure you don't lift up parts of it. I may have to redo it again, but I won't unless I really have to.sablabra said:I guess you put it on with the foam thing against the mobo, and not the metal?Well no problems for me, the isolating works fine, and seems a lot more robust than those made of plastic(would be surprised if it wasn't, as it's made of solid metal
Well the beast arrived today, and I'll fit it tomorrow. I can tell you already though that it looks like it's going to be easier to put in place than the Typhoon. The Typhoon comes with screws you screw through a spring loaded "clip" (not really a clip) while the thing is on the motherboard. You need a bit of space for that, and my Antec P150 is a bit too small making it hard to screw the top screw properly. It was a tricky job getting it on, and after three attempts I'm still not sure I got it entirely right.
The Ninja comes with a retention bracket that you put in place of the one that's on the motherboard (which I had to remove for the Typhoon anyway, so it's gone), and a backplate if there is none with the motherboard (there is one already attached on my A8N32). Screw the bracket into place, then clip the Ninja onto the retention bracket using the two spring loaded clips. Looks easy, but I'm probably tempting fate![]()
Not so far, but I need to re-do the AS5 when I can be bothered. If you're happy with the XP-120 and there is no reason to change, I wouldn't bother. If you're worried about memory slots being blocked, I'd get the Typhoon. If you're worried about case airflow, I'd get the Ninja. Overall, everything taken into account, the Ninja should 2-3C cooler than the Typhoon under the same circumstances. In terms of mounting them (in the case, as that's what I did), the Typhoon is easier - to get the Ninja clipped into place you need to apply some steady force.Did you find the ninja better than the big typhoon in the end. Not sure whether to go for a ninja or big typhoon to replace my xp120
