Hi all
I have a 3900X being cooled by a Scythe PCGH5 cooler and I'm not happy with the temps I'm getting. I run BOINC 24/7 and am often seeing temps within the 90 degree range which is way too hot for my liking. Can you recommend me any replacement fans for my HSF? I am runnning in a BeSilent 800 Case and I have aleady swapped the front fan out for 2 Arctic P14s. At idle my temps in Ryzen Master are showing as 47 which I again believe is a bit high
Thanks
Thanks
