SCYTHE S-FLEX™ 120mm FAN
19 May 2005
shropshire
SCYTHE S-FLEX™ 120mm FAN has anyone tried these fans if so are they as quite and as good as is said about them specs are
Dimensions: 120x120x25mm
fan Speed: 800rpm
Noise Level: 8.7dBA
Airflow: 33.5CFM
Power: 0.10A
megatron said:
Seems nice until u realise u can buy four xurillian 120mm fans instead.
xurillian fan is actually a googlewhack :D
Saw the scythe fan for $15 so i guess these are only about $4 each?
XinRuilian 120mm Fan 0.18A
# Adapter - Molex 4 pin
# Voltage - 12V
# Current - 0.18
# Speed - 1700RPM
# Airflow CFM - 65.12
# Noise dBA - 30
# Depth - 1"
Spelt it wrong!
£5 and use fan controller or a 7volt convertor, I know my ys-tech 120mm wont run on 5v though.
£20 for the fan as per topic sod that...i'd rather pay that and eat beans and fart through my rad too cool it
