SD card for my compact?
20 Aug 2006
Liverpool
Hi, I have just purchased the BenQ C1230 from OcUK as its on the today only deals for £19.98. This is going to be a birthday present for my mum as it seems nice and simple to use.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-050-BQ
Now, i will need a SD card but the description on Overclockers and BenQ web site says
4GB SD compatible / 32GB SDHC card compatible
will this 4Gb micro SDHC card be OK (as the description says 4Gb SD and not SDHC):confused:
http://www.overclockers.co.uk/showproduct.php?prodid=FL-010-KS&groupid=1657&catid=1908&subcat=1767
I was just looking at the price as the micro SD is 20p cheaper :D i am not made of money :D
If that one you linked to will work then i will order that, thanks.
