SD card not picked up
25 Sep 2006
Hi,
Not quite sure if this is the right sub-section.
I have a card reader in my laptop and a 1gb micro sd card, and the micro sd card adapter to make it a regular size SD card to work in the reader. However it is very temprimental and even though it is recognised in my computer, i cannot explore it as it tells me to insert a disk into the drive.
My 8gb micro sd came today and this has a usb adapter, yet the same thing is happening. Does anybody know of the solution? My OS is vista if this helps.
Thanks
Benny C
Are the cards both SDHC? If so this could be your problem, your card reader might not be able to read SDHC cards.
Hi,
Thanks
Benny C
Do you mean the 8GB in it's bundled reader is not working, or do you mean the 1GB card is not working on the new USB adapter?
Make a table like
8gb sdhc + bundled reader = ok
1gb sd + bundled reader = not ok
1 gb + built in reader = not ok
8gb sdhc in+ built in reader = ok
Then we can work from there. Also try and see if the 1gb is SDHC, I know the 8GB is, as there are no non-SDHC 8GB cards around.
