Hi,
What is needed for the SD card reader on the Lian Li V354B to work? I mean, where do I connect the cables? Do I need some kind of internal SD card header on the motherboard (never seen one) or do they go to USB (highly unlikely?!)
There's nothing on Lian Li's site and the "manual" doesn't mention it (other than it's there).
http://overclockers.co.uk/showproduct.php?prodid=CA-238-LL
Cheers,
Cheers,
