SD Card video recovery
30 Aug 2006
I need to recover videos from an SD card that was used in a camera, I delete the videos without backing them up. Do any of you have experience with this? I'm looking to get some software, purchased or free, to use to get the job done. I'm wondering if there are any preferred or reliable ways to do it.
Hopefully this will be a one of thing and wont happen again, so nothing too expensive.
EDIT : I saw a few photo recovery links in the main sticky, but they are from over 10 years ago, I'm thinking this have changed a bit since then.
Just stumbled across this (I know it's old now), but I had the most success with the code below (admittedly this was for .mp3's)
CMD prompt:
To search for a specific file named important_document.pdf that was in the \Users\Bob\Documents folder on drive C:—and then save it to drive D:—you’d use:
winfr C: D: /n \Users\Bob\Documents\important_document.pdf
To recover all deleted MP3 files from your C: drive and save them to your D: drive, you’d run:
winfr D: E: /r /n *.mp3
Hope that helps someone...
