21 Jul 2008 at 07:27 #1 Privateer Privateer Associate Joined 21 Aug 2005 Posts 357 what the difference between, Micro SD and Micro SDHC.
21 Jul 2008 at 07:38 #2 PhillyDee PhillyDee Soldato Joined 12 Feb 2007 Posts 14,117 Location South Shields Micro SD is secure Digital. SDHC Is Secre Digital High Capacity. They arent compatible unless the equipment is compatible. So check your manual.
21 Jul 2008 at 07:40 #3 melbourne720 melbourne720 Associate Joined 26 Sep 2006 Posts 1,945 Location West Bridgford 4GB and over, SDHC http://en.wikipedia.org/wiki/SD_Card
21 Jul 2008 at 10:19 #4 Plasmoid Plasmoid Associate Joined 8 Sep 2005 Posts 303 Location Leixlip, Ireland Bottom line if its SDHC assume its not compatible unless you know for certain it is. Easy to get burned.
21 Jul 2008 at 10:26 #5 MoRT489 MoRT489 Soldato Joined 21 Aug 2006 Posts 7,512 the move from SD to SDHC probably means you will need new card readers (unless you got them relatively recently), i did.
21 Jul 2008 at 10:47 #6 Privateer Privateer Associate OP Joined 21 Aug 2005 Posts 357 my kids have LG- Shines that take Micro SD, So Micro SDHC will not work, I must get the 2gb Micro SD. thanks everybody.
