Guys i need some advicce, turned on my PC at work this morning and got a '0x0' error when booting from my sammy 128gb SSD drive. Tried W7 disk repair options & chkdsk /f both of which failed.
So i put it in an XP machine and just before the login screen XP repaired the drive.
The drive now appears to be partitioned in to 'System Reseved E:' 100mb and 'F:' for the rest of the drive.
The user folder has dissapeard! i can see the files under Recuva but in a renamed directory.. i.e \dir0003.chk\documents\letters
Is there any way to rebuild the user & directories or do i need to recover the files i need then re-install windows?
Also whats the chances that the disk will be corrupt and fail in the future.
