SDOC 100 Gel
2 May 2004
Ordered myself some SDOC 100 after hearing plenty of good things about it. Just one worry though: how tough is it on grease/lube? i.e. should I be re-applying grease etc. after using SDOC?
It's amazing stuff, but I don't spray it where I'd need to lube something, unless I want to clean it to re-lube, if that makes sense
Best soap I've used, I had a sponge that was black with oil and it came back out of the wash bucket nearly like new after using SDoc.
I'm the biggest sceptic in the world and unless they've changed the formula recently, I think you will like it.
