Currently looking at 2 laptops, and just noticed something on the RAM specs.
One says "8GB 2 DIMM (2x4GB) DDR3L 1600Mhz".
The other "8 GB 1600 MHz DDR3L SDRAM (1 x 8 GB)"
It was the 'SDRAM' that caught my eye, and did a quick search on it, and was hard to find a good answer and way to compare them. And actually a few sites referred to it as old and half the speed of other types of RAM.
Is there anything in this? Is it simply because of it just being 1 stick of RAM? Or is there actually a difference between the two?
Thanks.
Thanks.
