SE d750i - sat nav?
6 Jan 2006
Newcastle upon Tyne
Hi guys. Just wodnering if anyone knows if its possible to get some software to beable to have sat nav on my phone?
I know I will need a GPS receiver, bluetooth I think right? Is there anything else that I need?
Thanks for any help
Mark
I don't think your phone will run a sat nav application. To see if it will check the likes of tomtom etc to see if they say they support it.
You can get some Java software from either Navig8 or Wayfinder though these require monthly subscriptions and the use of GPRS to download the maps so you have to pay data charges as well. To use TomTom you need a smartphone. I personally wouldn't bother with the non-smarphone GPS solutions - they work out too expensive - better getting a TomTom One.
