Hi all,
I'm thinking of upgrading my cpu cooling. At the moment there is an fenair Titan air cooler sat on my intel core 2 quad q6600, socket 775.
I know old kit.
I will be upgrading within the next 18 months and so this leaves me with a decision.
I want a water cooler that will fit both this cpu and newer ones once I upgrade.
YOUR BASKET
1 x Corsair Hydro H110 280mm High Performance Liquid CPU Cooler (CW-9060014-WW) £91.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £88.00
Total : £189.59 (includes shipping : £8.00).
I'd really like the Corsair h100i, but it says it doesn't support my current socket. Do overclockers stock the 775 backplate that can be used to mount this? I know corsair make one but I'd rather not consider importing one?
If I went with the H110, which says it support 775, what do I gain with the 10 and lose with the i? (the corsair link thing isn't it? and is that significant)
I dont think my old coolmaster cosmos I case will have trouble fitting either radiator.
Any advice?
I know old kit.
YOUR BASKET
Any advice?
