- 20 Sep 2020
I have recently built raised decking using scaffolding boards, pine I think, as decking. I wish to use the space underneath for storage but need to seal the gaps first. Can't use a membrane due to the support beams being below the board level. Have used silicone but can't paint over it effectively and wood filler just cracks. The gaps vary from 2mm to around 5mm. Any advice greatly appreciated.
