Sealing/waterproofing laminate after it's been fitted
Don
18 Oct 2002
Notts
We have the click type laminate in main bathroom and water gets between the joints and it starting to swell a bit in places at times
Is there anything I can apply to it, sealant or something while it's still in situ?
I'm not the greatest at DIY so hopefully something not too tricky
Thanks
TBH I would replace it with a waterproof laminate. The reason is that sealing it will not be 100% effective, will be quite expensive and will change the look of the floor.
its supposed to be waterproof but the joints aren't think they should have been done when laid
replacing will be tricky as it goes under the units, bath etc
The thing about trying to add a finish/sealant is it might not match or adhere to the existing finish on the surface. IMO as above laminate isn't ideal for bathrooms or kitchens. You need more stable material.
