searching an SQL database with a form
1 Dec 2004
S.Wales
Im looking for any decent tutorials on the net to implement a form echo'd in PHP so that when the user enters some sort of word/string and click submit, it will query the database for that string and return any results.
Iv been looking on the net for tutorials/examples but cant find any.
If you know of any can you post the link for me to read up on it..
thanks
The query is:
SELECT * FROM Videos WHERE MATCH (TableName) AGAINST ('user_input');
Here's some code:
search.php:
Code:
function remove_magic_quotes($array) {
	foreach ($array as $k => $v) {
		if (is_array($v)) {
			$array[$k] = remove_magic_quotes($v);
		} else {
			$array[$k] = stripslashes($v);
	return $array;
if (get_magic_quotes_gpc()) {
	$_GET	= remove_magic_quotes($_GET);
	$_POST   = remove_magic_quotes($_POST);
	$_COOKIE = remove_magic_quotes($_COOKIE);
$input = strip_tags($_POST['userQuery']);
$sql = "SELECT * FROM Table WHERE MATCH (FieldName) AGAINST ('$input');";
$result = mysql_query($sql);
while ($field = mysql_fetch_array($result))
	$searchResults = $field['FieldName'];
	echo '$searchResults';
The form - search.html or whatever:
Code:
<form name="form1" method="post" action="search.php">
  Query:
  <input type="text" name="userQuery">
  <input type="submit" name="Submit" value="Submit">
</form>
I'm not really sure on the security of this as I have never had to use this properly, I have only ever messed around with it. Maybe someone else can fill in any security I have missed? :)
Untested, but it should work ;)
Hope this helps
Craig.
Thanks mate, instead of using a seperate php file for this cant i place it in my .php file where i have the catalogue front-end? place it inside <? ?> tags.
what would i point the form to then?
<form name="form1" method="post" action="???.php">
atm iv pasted the code in the relevant places so now it looks like this
Code:
<div id="catnav">
<a href="index4.php?show=DVD"> DVD</a><br />
<a href="index4.php?show=video"> Video's</a>
<br />
<br />
  Search:
</form>
		if (is_array($v)) {
		} else {
	return $array;
</div>
<div id="catcontent">
$username="";
$password="";
$database="caldico_mediacat";
mysql_connect(localhost,$username,$password);
@mysql_select_db($database) or die( "Unable to select database");
//If the $_get function == DVD then get execute the following statement
if($_GET['show'] == "DVD") {
//If $_get == dvd then execute the following SQL query and output the results
$query="SELECT * FROM DVD ORDER BY catagory ASC";
$result=mysql_query($query);
$num=mysql_numrows($result);
mysql_close();
echo  "<b><center>Database Output</center></b><br><br>";
$i=0;
while ($i < $num) {
$catagory=mysql_result($result,$i,"catagory");
$director=mysql_result($result,$i,"director");
$title=mysql_result($result,$i,"title");
$price=mysql_result($result,$i,"price");
$image=mysql_result($result,$i,"image");
//Output display
echo '<div align="left" class="product">';
echo "<b>Catagory: </b> $catagory <br></br>
<b> Director: </b> $director<br> </br>
<b>Title: </b>$title <br></br>
<b> Certificate: </b> $certificate<br> </br>
<b>Price: </b> $price<br></br><br>";
echo '<img src='.$image.' />';
echo "</div>";
$i++;
//else if $_get function == video then get execute the following statement
}elseif($_GET['show'] == "video") {
//If $_get == video then execute the following SQL query and output the results
$query="SELECT * FROM Video";
mysql_close();
$i=0;
while ($i < $num) {
$certificate=mysql_result($result,$i,"certificate");
//Output display
echo "</div>";
echo "</div>";
$i++;
</div>
The problem is when i click submit button it wants to open search.php
Ok im getting this error
http://www.caldicot-pc-helpdesk.co.uk/fcv/database/search.php
with this line
search.php
Code:
		if (is_array($v)) {
		} else {
	return $array;
You need to change the field/table names etc. in the query.
Also in the form you change post="" to whatever file has the search code.
Craig.
Yeah but im going to search the whole database for what ever $input is rather than searching tables and fields?
Code:
		if (is_array($v)) {
		} else {
	return $array;
Code:
The above is the query that is run when someone submits something from the search form. It matches up "FieldName" against $input - $input is whatever was put in the form.
For example, lets take it you have the table named Links and in there are the fields ID, Title, URL, Date & you wanted the user to be able to search within Title & URL so you'd do this for the query:
Code:
$sql = "SELECT * FROM Links WHERE MATCH (Title, URL) AGAINST ('$input');";
Also, make sure you change input in the $_POST['input'] bit according to what the text field is named in your form.
Craig.
But as stated before i want to be able to search the whole database not just a specified table.
E.G
I go on catalogue and i have the search fields, i want to be able to type in wedding crashers which will return results back from both DVD and Video tables with all the relevant fields.
Your example searches a specified table & field for results.
You'll have to search each table individually or do a union of the results (will only work if sleected fields are of the same schema.
You can't really 'search' a whole database, you can search specific tables within that database.
ok so maybe an implementation of a 2nd form item on the page, namely a dropdown box which lets you choose the table you want to search? but then your still going to have a problem of which field your actually searching for?
Would this call for another drop down box with the field name?
e.g.
Search field
Drop down (Tables)
Drop down (Fields)
so say i could search for:
Wedding crashers
DVD (Table)
Title (Field)
If you use a dropdown box then you could do something like this:
The dropdown box (within the form that will later post to get the result(s)):
Code:
  <select name="select">
	<option>item 1</option>
	<option>item 2</option>
	<option>item 3</option>
  </select>
Then in the query you would do this:
Code:
$searchTable = $_POST['select'];
$sql = "SELECT * FROM $searchTable WHERE MATCH (Field, Fielda, Fieldb, Fieldetc) AGAINST ('$input');";
If you use the way above then it'd be best to name your tables well (capitals etc.) as you'll have to have the menu item the same name as the table name.
Craig.
Nice one, thanks mate :) Will give that a bash!
Presumable i would just amend the search.php file to accompany this query replacing the one you previously gave me
Code:
$username="";
$password="";
		if (is_array($v)) {
		} else {
	return $array;
$searchTable = $_POST['tables'];
$sql = "SELECT * FROM $searchTable WHERE MATCH (Fields) AGAINST ('$userQuery');"
$result = mysql_query($sql) or die(mysql_error());
$sql = "SELECT * FROM $searchTable WHERE MATCH (fields) AGAINST ('$userQuery');"
Craig321 said:
Code:
  </select>
That wouldn't work because you haven't assigned the options values ;) It needs to be
Code:
	<option value="item1">item 1</option>
	<option value="item2">item 2</option>
	<option value="item3">item 3</option>
  </select>
EDIT: And if you're going to put the search form in the same file as the searching code, you need:
Code:
<?php
if (!isset($_POST['submit'])) {
// form code etc
<?php
} else
// searching db code
and
Code:
<form action="<?=$_SERVER['PHP_SELF']?>" method="post">
Im still getting the
Parse error: parse error, unexpected T_VARIABLE in /home/caldico/public_html/fcv/database/search.php on line 32
error message on that line which has something to do with..
Code:
		if (is_array($v)) {
		} else {
	return $array;
//THIS LINE
[b]$result = mysql_query($sql) or die(mysql_error());[/b]
the line identified by bold
no change with the following
Code:
$sql = "SELECT * FROM $searchTable WHERE MATCH (catagory) AGAINST ('$userQuery');"
I don't think your problem lies with that as when I copy and paste your code, line 32 is blank :confused: Where you have
Code:
echo '$searchresults';
remove the quotes:
Code:
echo $searchresults;
