Searching for a case
17 Jan 2016
Schlüchtern, Germany
So i need a new case with these requirements:
360 rad in the front
240 rad in the bottom
120 rad in the back
Before you ask, NO i do not want a top mounted radiator instead!
The case should have a simple boxy design. (Like fractals define series or corsairs obsidian series)
It shouldnt be too large either. (for comparison: Corsair obsidian 750D would be ok a 900D would be way too large)
aceCrasher is online now Report Post
Seems weirdly specific not wanting the rad in the top without any reason given... But I don't know of any 'smaller' cases which carry that space at the bottom. Perhaps you should just search for those which have a top PSU mount, ultimately that is what will dictate it.
Corsair 540 with some modding to mount a bottom rad as that'll take a 360 at the front a 120 at the back and if you did go top mount you'd fit the 240.
Take a look at the Corsair 600Q or 600C, I have a 60mm thick 280 in the front and a 60mm thick 240 in the bottom of mine but depending on your rads you may be able to fit a 360 in the bottom instead.
I do not want a rad in the top of the case so i can dampen it off for noise reasons.
