Searching strings in C++
10 Apr 2004
Im importing a passenger data set using C++, for example, if a user wants the details of passenger ID 1, they enter 1 and they get back:
Code:
1  Neil Armstrong            American Airlines        8 30   Chicago International       AA101
Now I need it to also get the Gate Number, which is many lines further down the file. Further down there is:
Code:
Flight No.  Gate  Boarding Time
AA101       4      7 30
HH202       2     10 00
What kind of command(s) should I use so that as it fgets through this part of the file it spots that the flight numbers match and that it should pull out the Gate number?
I've tried a simple
Code:
				sscanf(string, "%s %s %s %s",flight_number_2,gate,time_hours,time_mins);
				if(flight_number==flight_number_2){
					break;
				printf("%s %s %s:%s\n",flight_number_2,gate,time_hours,time_mins);
But unfortuantly that didn't work :p
Any hints would be nice :)
Cheers
not too sure if C++ is the same as C, but in C you can't compare 2 strings using ==, have to use strcmp(string1, string2), from the string.h library.
