- 18 May 2010
What happened to Seasonic's PCI cables?
I've had a few Seasonic PSU's in the past and the flat cables were decent as they didnt stand out but these things are thick and then have a flat splitter coming off of them which makes no sense to me because I read its recommended to use two cables if the GPU has two 8 PIN ports
Because of this I have two huge PCI cables with two splitters dangling right in the middle of the build which looks terrible
Are they so thick because you can just use one cable, the only info I can find on the internet is its best to use two cables rather than one, I used two in my last build and they were Seasonic but because they were flat they were much easier to neaten up
Thanks
Thanks
