- 6 Apr 2025
- London
Hi,
Final component on my build here.
Originally I wanted to order the Seasonic Focus GX following some advice from the helpful members of the forums, but it is on pre-order. I contacted OC and they said they have no ETA which is a bit frustrating.
So from what I read around, the Antec HCG Pro platinum is similar to seasonic but what about the noise level?
The build is white, and I don't want a lot of noise. I saw that the seasonic one has a Cybenetics Noise Level of "A-", while antec is unrated.
The platinum vs gold is only 2% efficiency which is a bit underwhelming of a difference.
So, Should I order the Antec or wait on the seasonic?
Thanks
Thanks
