Seasonic PSU
10 Jan 2014
Hi, I'm building a new PC. I'm thinking of getting this PSU and would like to know if it will run all My stuff with no problem ?
PSU.. Seasonic 860w '80 Plus Platinum' Modular Power Supply..
I will be running a EVGA Classified GTX 780Ti Graphics Card
Intel 4930K 3.40GHz (Ivybridge-E) Socket LGA2011 Processor
TeamGroup Xtreem LV 16GB (4x4GB) DDR3 PC3-20800C10 2600MHz Dual/Quad Channel Kit
And Possibly this water cooling ( XSPC RayStorm Twin D5 AX360 WaterCooling Kit )" But haven't decided what Water Cooling system to get yet ?? "
Many Thanks :)
Should do comfortably - my 4820K (@4.4GHz) w/ 780 (boosting to stock 780ti performance) pulls about 360-370watt in BF4 with ultra settings.
I'm running the Seasonic 760W Platinum which i bought from Overclockers, its a fantastic PSU. Its running a Sapphire 7970 3GB Vapor X, i5 3570k ivybrigdge, high end sound card etc etc and it doesn't even break sweat, you can't hear it at all.
I know I am probably too late, but I would have gone with the Corsair AX860. It's £20 cheaper for the same psu (Seasonic made).
YOUR BASKET
1 x Corsair Professional Series AX 860W '80 Plus Platinum' Modular Power Supply (CP-9020044-UK) £149.99
Total : £159.59 (includes shipping : £8.00).
Cheers Mate, But I'm going to order the Seasonic Thanks. They have really good revues. Although the one you recommended has as well. But the Seasonic wins for Me. Many Thanks for your input ;-)
