I am thinking of buying the Seasonic S12 430W Silent ATX2.0 Power Supply for a new build but am a bit concerned over a couple of points
1. It does not seem to have the 6 pin socket needed for PCIe cards. Is there a simple workaround for this ie Adapting one of the other leads
2. The length of the leads seem a bit shorter than others. I am not expert on what they should be or even if this is a problem Should I be concerned
Thanks
Mike
Thanks
Mike
