Second hand gaming laptop advice
19 Apr 2012
Evening all,
I recently took a wild stab on a laptop that has a 6800H and a 3070ti. It was offered for less than a 5800h/3070 equivalent.
I assumed a scam as the seller had zero feedback but I used protection (ooh err).
It arrived and only with it's Lenovo box but sealed with sticky sand paper (? Bizarre) No outer packaging which had split so laptop was visible through it's journey.
Surprisingly, it's in amazing condition, ran a few tests (steel nomad mainly), someone had forced the igpu which was performing crap, it's still below the average currently but I think I repaste may solve it as internally it looks good but fans and heatsinks have been off.
The secondary SSD was left in it ( didn't realise there was one) and not showing but bent down to the main board as they hadn't put the riser in correctly. It's now showing correctly.
Anything else you would check before accepting it?
Do you happen to know if single rank Vs dual rank ram has a big a benefit on the 6800H? If I recall dual rank on the 5800H gave a decent performance bump.
Only a guess but I'm assuming so, I have the 5800 and wish it was dual with the higher speeds.
It definitely has been opened before so I'm unsure if that will have any issues with the remaining warranty. The void stickers have been tampered with.
I think I'll get some phase change pads for doing it if you think it will affect warranty. CPU hitting 101C during gaming.
Shouldn't be an issue, the tech who comes out doesn't care. Just say you opened it to clear the dust from the heat sinks. My experience of Lenovo warranty is very good.
I hope it was really cheap as you're putting a lot of time and effort into this.
Good shout. Shall do!!
It was £540 delivered which I felt was pretty cheap for the spec. Every other one with a 3070ti was around £750-£800.
