second loop for NB/SB/MOSFETS
3 Aug 2008
Bath, England
Hi peeps,
i'm going to add a second loop over the summer to accompany this loop:
Apogee GTZ
2xEK Supreme gpu only blocks
XSPC dual bay res
Laing Vario
PA 120.3
7/16 hose
i'm planning on using a PA 120.1 and a combo of EK mosfet blocks and swiftech NB/SB blocks, with a single bay res on 3/8 hose.
Firstly, will a 120.1 be enough to cool both fets and nb/sb?
And which pump would be ideal for this loop?
specs in sig if needed ;)
I would guess that a 120.1 will give you no advantages over air cooling the heatpipe array in even a half decent case
or using a single spotcool fan.
Look at the watercooling case gallery and see how few full watercooling setup there are on new chipsets.
If your case airflow is poor spend the money on a new case.
That what I'd do if I still used fans.
