Upgrading to an AMD 3600 on an X570 board, out of the below options which would you guys recommend:
Alternative suggestions are also welcome!
Primarily for gaming, will also be upgrading to a new gpu (keeping my current one for now) when they drop, along with a ryzen 4000 at some point. In essence, I’ll be limited by other components in the immediate future, however happy to spend a reasonable amount on RAM now, so that when I do upgrade it will be of the same calibre so to speak.
https://www.overclockers.co.uk/team...3600mhz-dual-channel-kit-black-my-001-8p.html
https://www.overclockers.co.uk/team...4000mhz-dual-channel-kit-black-my-098-tg.html
https://www.overclockers.co.uk/cors...zen-tuned-ddr4-memory-dual-kit-my-4c1-cs.html
My knowledge of RAM isn't great, and whilst I’ve read around the forums it would be very helpful to get a concise but thorough breakdown of which option is best.
From what I gather clock speeds takes precedence over Cas timings. so whilst the first option by 8 pack has impressive timings, in theory the second option with the 4000Mhz clock should perform better.
Additionally, I know compatibility can be an issue with certain configurations. I’ve read the 3600mhz + is not officially supported so can lead to problems. However I’ve also read the opposite, as well as manufactures claiming speeds of 4000mhz to be compatible.
So would be good to get an opinion on this!
Thanks
Thanks
