Second screen acting weird
2 Sep 2010
Somerset
I have just got my replacement monitor and have set it up as dual screens, both monitors are Benq G2420HDBL's. The problem is, when I set it up as an extended display, it shows the left hand side of the monitors image on the right and the right hand side of the monitors image on the left? However, when I try the monitor on its own, it is fine. I have uninstalled and reinstalled the drivers and also tried disabling and re-enabling crossfire but it makes no difference.
Basically, it does this. When i move the mouse across the screen, it is fine up until the second monitor at which point it shoots to the right hand side of the screen and if I keep going, it appears on the left hand side.
Very strange and I do not know what to do :confused::(
Just connected the second monitor to the second card via hdmi and it works fine? Do you think the HDMI port on the first card is nackered?
