Currently using a Yamaha RX-V681 AV receiver.
I wish to add a speaker in the kitchen so can hear whatever is being played from the Lounge where the Yamaha is.
Any tips on how to achieve this?
A Yamaha Music cast device?
Can you play through main 5.1 and the Music cast at the same time, for example, have a program on in the lounge and play to the Music Cast device with the same content at the same time? *Obviously, tied to Yamaha if wish to change Amp in the future.
Any Bluetooth Speaker?
Distance is about 10 metres/32ft, is this too far for Bluetooth? Is open plan so no walls to pass through, just a doorway.
Run speaker cable into kitchen?
This is possible but with corners etc, cable run would be about 15 metres which with some decent cable is doable (I think?) and would have a good choice of speakers. *I could connect the speaker to the second zone on the AV system meaning could play seperate content too if needed.
Another option which I have no idea is possible, is connect the second zone outputs on the amp to a mini amp of some description then attach a bluetooth transmitter? No idea if this makes sense but kind of works in my head bot not sure of the practicalities. Can then use any generic bluetooth speaker for a dirty setup.
Thanks for anyone who has taken the time to read and thanks for any input.
