I get this now and again when visiting different websites:
Secure Connection Failed
olb2.nationet.com uses an invalid security certificate.
The certificate is not trusted because the issuer certificate has expired.
The certificate will not be valid until 01/11/2007 00:00.
(Error code: sec_error_expired_issuer_certificate)
* This could be a problem with the server's configuration, or it could be someone trying to impersonate the server.
* If you have connected to this server successfully in the past, the error may be temporary, and you can try again later.
Or you can add an exception…
I am using Firefox. Is this a Firefox issue?
Edit: Think i may have solved it! My date and time were out on the PC. Corrected it and all is ok now!
