secure login system?
6 Mar 2008
Stoke area
Hi all,
I am currently looking at building a secure website for some of our business needs, however it will to first load a login screen that will have multiple users & passwords.
I want to learn PHP/SQL anyway so I thought, what the heck :D
very little knowledge of PHP & SQL, I know programming basics etc.
Does anyone have a link to a basic guide for creating a login system that is secure and explains things simply?
I've found several already, firstly a PHP that stored passwords in a php folder which obviously isn't that secure, and a couple of others that dont really explain anything!
Things to consider:-
Sanitising user input before doing anything with it
Hashing (and salting passwords) - not storing them in plain text
Sessions
If you use md5 or even most hashing algorithms, salt it before you hash it. Protects against rainbow tables etc.
Hi all,
If you want to do it properly and have multiple users then your best storing user names and passwords in a database.
Your basic script will most likely follow these steps (assume user has just entered user and pass into a form):
- Get posted form values and clean input.
- Execute SQL query based on inputted user and pass (E.g. select user, pass from tblUsers where pass='hsdghksa' and user='shdfiuds')
- If exactly one match correct details (Set something like a session variable at this stage) direct to protected page/area
- If no match, incorrect details, display message etc.
If I was you, I'd personally try making your own. I always seem to understand and remember how to do stuff this way :)
Salt and hash passwords; check any stored (i.e. session/cookie) logins on every page load, not just when setting them; only allow X login attempts per Y seconds/minutes; use HTTPS if possible.
That should cover most bases. I'm sure anyone here will explain individual things if you're having trouble with them.
sha1(salt + password)
Depends how sensitive the information is you are protecting, you're not going to expend hours and hours to break in to a user area of a website, and because of that, MD5 works for me.
