I'm currently living in a shared house and the private wifi network we have has had some shenanigans going on with it, with weird dns servers set on the router that have blocked some websites as well as an unknown ring device on the network even though we don't have a ring doorbell.
I'm treating it as a public network at the moment but would like to ensure a more robust protective measure for my own devices, I did consider getting a cisco integrated services router and putting all my devices on a different network, but the cheap house router supplied by the ISP doesn't support a point to point connection over the LAN as far as I can tell and there's no way to manually alter the routing table on it, so the default gateway 192.168.1.1 wouldn't know how to get to 10.0.0.1 if I set up my own network using that as the default gateway would it? It's been a while since I did my CCENT lol.
So is the best solution to buy a firewall with switching instead and put my own wifi access point and ethernet devices behind that? I know some support a VPN as well, though I would still like to be able to access some devices on the house network like the printer.
I'm pretty sure the router supports vlans and subnets, however the house router can't be trusted as other people have access to the administrative control panel and could change the settings. Currently I'm just running a CAT8 cable from the router to a cheap switch in my bedroom.
I've heard pfsense is pretty good but I've never used it before whereas I'm very familliar with Cisco's OS.
Any advice would be appreciated, thanks.
