securing wired and wirelss PC's
8 Apr 2004
OXFORDSHIRE
Hi, just recently got BeThere Value Wireless ADSL for myself and housemate. I have an older PC with WinXP SP2, and she uses a modern ( Acer ) laptop with Wireless built in and VISTA
Since i'm the one with the modem right next to my PC, and the fact that i only have an older style Net card, i'm wired to the router. Her downstairs is Wireless.
When i was setting it all up, i had what i think was a secure WEP key code printed on some of the vast amount of paper that comes with the BeThere kit , though now i cant be certain because the paperwork has gone somewhere ( could still be in the house though ) and i dont know how to check that i DID type in this key when setting up.
Regardless of this, should i re-do all the security using WPA-PSK ? And even though i'm not using Wireless on MY computer, do i still have to type in the same key as would be used for her downstairs ??
Security wise, i'm a tad green, as this is the first time i've had a proper Wireless modem.
If anyone has a decent link to any help /guide on how to set security on these 2 different setups ( one PC wired, running WinXP SP ....one Lappie wireless, running VISTA )
THang yow !
If you can access the router/modem config page (i.e. something like 192.168.1.1), the WEP keys should be shown there. What router/modem is it?
WEP should suffice for a home wireless setup ;)
The WEP key the BeBox came with is printed on the bottom, though WEP is completely useless for any setup...
You don't have to use WEP/WPA et al if you don't use wireless. The encryption only applies to the wireless.
Hi - tried that and the page just remains blank for eternity. Modem is a THOMSON.
heavens - never thought of looking under the box!!
There's an SSID number ...a WEP number... a WPS PSK number. I guess i must have initiated one of those numbers upon first set up, but which, i dont know.
All i'm after really is to stop other people near enough to me piggy backing off my connection.
So i dont need to set WEP / WPA on my PC ? Thats good news - so just on the Laptop then
The default IP is 192.168.1.254.
Thanks T ..just got on there. What am i looking for mate ??
OK i've found it. Its WPA PSK enabled, and the number is visible to me now that i've navigated around the Modem/Config site.
WPA-PSK Preshared Key: *******
WPA-PSK Encryption: TKIP+AES
WPA-PSK Version: WPA+WPA2
Cheers and thanks all !!!
