Seeking advice, are the components for my custom build compatible?
30 Mar 2014
Hi guys,
I'm a small time amateur PC enthusiast who built his first PC with the help of a more experienced friend a few years back, and have now been asked by my girlfriend to put together a custom build for her too. I've got a build together that fits her needs and exists within our budget, I'm just wondering if anyone could let me know if all of my chosen parts are compatible? Any advice would be appreciated as we would like to purchase today with Black Friday sales still going strong :]
Case - Bitfenix Nova Midi Tower Case
CPU- AMD Ryzen 5 2600X w/ Wraith Spire Cooler
GPU- GIgabyte GTX 1070 8GB VRAM
MOBO- MIS B450 Gaming Plus Max
Wi-Fi Card- Gigabyte GC-WB1733D-I, measures 21 x 14.8 x 5.6 cm and is the V5.0-1733MBps model.
RAM- Corsair Vengeance LPX DDR4 3200MHz 2x8GB
PSU- Corsair CX Series 650W Plus Bronze
SSD- Western Digital 3D NAND Internal 2.5 Inch SATA 500GB
No disk drive as we're going with USB OS install.
Any responses appreciated, speedy responses doubly so.
Thank you all kindly in advance.
You should go for a Ryzen 3600, not 2600. The 2600 is the previous generation. The sweet spot for RAM for the Ryzen 3600 is 3600 MHz and your SSD seems to be a little on the small size.
Thanks for the advice regarding the CPU and storage capacity.
I'm going to take the advice on the CPU and stretch the budget to the absolute max (bank account emptying levels) to grab the 3600.
The MOBO says 1st 2nd and 3rd gen ready alike so should be no issue.
The storage situation is just a stopgap until the next pay cheque as I need an SSD for the boot drive and also enough storage space to hold a few games for the first month of use.
Everything remains compatible with the 3600 in place of the 2600x right?
Thanks again.
£270
The bank account will be literally empty as is I cannot afford an upgrade.
I know that the 2060 Super is a good buy but I don't have the capital.
£270
That's a terrible price for a 1070 now.
My basket at Overclockers UK:
Total: £549.48 (includes shipping: £10.50)
And just £9 more will get you a considerably faster RTX 2060. That's without looking at Vega 56. Well let's look anyway:
Total: £258.89 (includes shipping: £9.90)​
Better than 1660Ti or 1070 and trades blows with RTX 2060.
Wow. Thanks for the links. Is that 2060 just as compatible as the 1070 in my instance?
No problem. Yes perfectly so. It uses about as much power as a 1070. You don't need a 650W PSU unless you're thinking of future upgrades. The parts you've chosen will run comfortably on a (true) 450W PSU.
Thank you. Yes there were upgrades in mind with the PSU. I'm getting my PSU for about £20 less with shipping factored in so I'm assuming the original 650W I had in mind will be sufficient.
