Seeking replacement for KHX1600C9D3K2/8GX
12 May 2021
Berkshire
I had a machine built by Overclockers back in 2014 and it seems like the memory is failing. I keep getting bluescreens in Windows 8.1 with the errors KERNEL_DATA_INPAGE_ERROR and MEMORY_MANAGEMENT. I ran the Windows memory diagnostic tool and it confirmed errors with the memory. I tried taking out and reinserting the memory, but the computer's still crashing.
I've identified the memory used to build the machine as Kingston KHX1600C9D3K2/8GX
https://www.kingston.com/unitedkingdom/en/memory/search/discontinuedmodels?partId=KHX1600C9D3K2/8GX
Please can anyone give me any guidance on what would be a suitable replacement for this?
Thank you,
Peter
You basically want 2x4gb ddr3 1600mhz memory unless you want more memory then 2 x 8gb ddr3 1600mhz.
Patriot 2x4gb Black Mamba DDR3 1600MHz but theese are tall so if ypu have a aftermarket heatsink check clearance
Corsair Value Desktop Memory 8GB (2x4GB) DDR3 1600 MHz
