seemingly impossible to tidy case
8 Jan 2007
Hey all,
I want to tidy my case wiring just to be neat but it seems that I can't get the tidy look that others have got on here. I need the molex connectors to go to the optical drives and to the fans and also to neons near th ebottom of the case. I can't seem to get rid of looking at wires through my window. Since my power supply is at the top like in all cases I don't really know what I can do and assumed there's a trick to this?? something I am missing?
Thanks
Try tucking all the cables you dont need into spaces like empty HDD spaces and behind your mobo. Also try routing your cables aroud the edge of your mobo against the side of the case (if they are long enough)
Got a photo of what you're working with? I tend to run my power and data wires on the back side of the 5.25" bays so they're not visible from the side panel. Extra long power and data cables can help. IDE cables are notoriously hard to keep tidy because of their size and relative inflexibility.
My ide cable ruins my case, it is only JUST long enough to reach from the top bay down to the bottom of my case bending round my graphics card, I bet it destroys airflow as well..
