Seidon 120v Ver2.0
23 Jul 2015
Hi everyone!
Just a quick question, Ive just put together my first watercooling setup. Ive used the Cooler Master Seidon 120v Ver2.0, paired up with an i7 3770 in a push/pull config. Where is the best place to plug in the pump and both fans? Currently got the pump and pull fan in the fan hub built into the case (12v I believe) and push pump is plugged into the CPU Header. Getting pretty much solid 32oC at idle. Is that all correct?
Thanks in advance!
