Hey Hey mate. yeap been reading all your posts. Extremely usefull tbh. Thanks a bunch Farooq. Do you game on it?
Firstly cheers mate glad I could help n pass on some user experiences and as for gaming to say I game on it would be a understatement I dont watch tv anymore I opt to play gams online while listeing to tunes and ventrillo with guild/clan mates being semi social while choring fps games like bad company 2/ cs source and of course the obligatory warcraft session that decends into the early hours for no apparant reason. only to find you have work early in the morning and only 4 hours to sleep.
basically I am heavy gamer like most of you on this forum lets be honest I watch downloads series like spartacus/dexter etc movies got my pc hooked up to a 1080p samsung tv nice gaming set up for after work relaxing.
but to answer your question they work excellent for all media games movies voice comms and music. In badcampny 2 for example the dolby headphone has to be heard to be belived you can pick up suttle noise cues and directional aids semi cheating your way up the score board with a little bit of help from good heaphones and excellent sound card. warcraft/ ventrillo/skype (Voip) is also excellent long periods online with zero difcomfort and I mean that they dont even sit on your ears they are circumaural (sit on skull) open backed which lets your ears breathe and not get sweaty after a short period. Plus you dont get horrible muffled sound from your own voice from closed back headphones like the goldring ns 1000.
Anyhow im done posting about 360's I have a few posts up and I think if you forum guys read them you will get the idea what the pc 360s are about and ideal settings and hardware.
http://forums.overclockers.co.uk/showthread.php?t=18234213
http://forums.overclockers.co.uk/showthread.php?t=18225053
pc 360's are really for hardcore gamer's only or people who spend hours on voice comms. They are not your run of the mill razer/creative/logitech efforts these is no comparison these are aimed at a different market all together you will need the following.
1. you really need a suitable amp to get best from them.That said the best from them is audiophile grade 558 / 595/ 598 sennheiser quality(high end) 28000hz+ range same part/magnet and part number used in drivers for headphones.
2 have a sound card that can do them justice any asus xonar or high end xi-fi like the HD will be fine. (Dont buy these and use on onboard audio its just wrong)
3 when using them make sure you leave mic boost off its a top of the range noise cancelling mic its does not under any circumstances need boosted and distorted just turn input sensitivty up if needed.
4 make sure you have windows speaker properties set to 24 bit 192000 Hz its marked as studio quality. This allows all programs ran in windows to use the higher sample rate not the default windows cd quality 16 bit by 44100 Hz which is low. also do this for for micraphone set to 192000Hz.
this is a run throughhow on how you set the above point 4 in windows7 even those without these pc 360's do this anyway it might boost your settings if you have not already.
control panal
sound
playback(recording for micraphone)
select desired device usually speakers
advanced and then defualt format.
set to maximum with studio quality 24bit ideally 192000hz (not all cards will go this high) sample rate varies with quality of sound card and chips used on them
This will allow you to change and get the best out of your hardware and headset cant stress how many people forget to do this.
