Got a corsair 700D and my cabling behind the mobo tray will not stay in place so it doesn't cause a bulge in the side panel so i am thinking of using the above to hold the cables in place and be able to put the side panel back on without crushing anything. Does anyone on here use them and if so do they work well in terms of sticking to the powder coat or did you have to do anything to get them to stick properly like sanding the case surface down. Have looked and found some 16mm clamps that look ideal but would like to hear some user's opinions before bothering. Case is being completely taken apart soon for my five yearly upgrade so will be perfect time to sort it out once and for all .
